Saving the maximum number
Help!! How do I save the maximum number? For example , I want the maximum value but if I were to have the next number, it shows the next number as the maximum value instead of my pervious maximum number which is a larger number . The first picture is how I got my values. It is just a sum of other values. What I want is to store the maximum number into the system.
Here below is how I get my maximum number. But it keep changing wether the fact that the next number is smaller or larger then my current value.
Is there a way to store the maximum number? I only want the maximum number to change if the next number is bigger than my current maximum number.
Message 1 of 9
(5,015 Views)
You should really stop and take some of the free tutorials. The solution is to use a shift register. I have no idea why you have so many local variables and why the min/max function is not in your main loop. Those should get fixed after you learn the basics.
Message 2 of 9
(4,993 Views)
Is this what you are trying to do?
Message 3 of 9
(4,990 Views)
I think the shift register combined the Max & Min is the right answer.
You can also consider the Array Max & Min PtByPt VI,
http://zone.ni.com/reference/en-XX/help/371361J-01/ptbypt/array_max_min_ptbypt/
Message 4 of 9
(4,970 Views)
no need for a SR, just use...
Message 6 of 9
(4,928 Views)
Hi apok,
how do you call (a single instance of) PtByPt-ArrayMinMax when you have 5 different scalar values to work with?
You need to build an array from your scalar values and you need to call your PtByPt function in a loop to get a proper result.
It's much easier to use the plain ArrayMinMax function…
Message 7 of 9
(4,921 Views)
@GerdW wrote:
Hi apok,
it looks like th Op wants maximun number of the addition of the 5 values and not maximun value of any one value
Message 8 of 9
(4,911 Views)
That's how I do it, but others might just drop down 5 copies of the PtByPt-ArrayMinMax and wire one to each of the scalar values.
Edit: or as mentioned this might be the max of the addition, more information from OP is needed.
Message 9 of 9
(4,910 Views)
