Saving the realtime images received from an IR camera(50FPS).
Hi I have an application developed in labview6.0 in which an IR camera is sending images(50FPS). I have to save these images into harddisk. But when I try this the system slows down and it effects the performance of the app also. It will be helpfull if somebody could suggest a way to store the images either on the system (NI PXI with 128 mb ram) in which my app is running or remotely on some other system.
(2,430 Views)
FOr a better answer than mine, I suggest you re-post this Q to the Vision forum.
Depending on the size of your images, the issue maybe a lack of memory.
50 FPS is also pretty high.
That is all I say for now, Vision is not my area of expertise.
Ben
(2,430 Views)
