Saving values from VISA Serial Read to an array
Are you using that array later in the program?  I am just thinking your code could be simplified to this:
for(i=0; i<=99; i++)
    printf("%f\n", read_adc()*5.0/256.0);
Message 21 of 24
(1,422 Views)
Yeah I use the array to find the amplitude, and frequency. And also to graph the waveform.
Message 22 of 24
(1,421 Views)
@JÞB wrote:
That explains a bit.
    printf("\r\n%f", (array[i]*(5.0)/(255.0)))
should be
    printf("%f\n", (array[i]*(5.0)/(256.0)+(5.0)/(512.0)))  //Assuming Vref=5V and 8 bit ADC (yes, you need to a 1/2lsb!) and printf now ENDs with the expected termination character rather than having it in the middle like that.
So I made the changes and did notice a few things. I have 2 read palletes in my code and the first one is for the array of values and the second one is for the amplitude, and frequency. So when the first read is executed, the array still only stores around 46 values. After that the second array with the amplitude and frequency is executed. After that is completed the values in just the second array disappear after a few seconds and when i try to flip the boolean switch to stop the program i get a "timeout experied before operation completed" error.
Message 23 of 24
(1,419 Views)
Inside of the pic?  That analysis should be done in your LabVIEW code.
Message 24 of 24
(1,417 Views)
