Sawtooth wave generation on Labview FPGA (Flex Rio 7966)
Hi sir, I have to generate a sawtooth wave on Labview FPGA in sctl (40Mhz clock). I have tried many methods nad even used FPGA DDS wave Generated. I am getting square wave as output although lookup table is sawtooth . I am attaching the code. Please look into that and help me in generating Sawtooth on FPGA.
Thanks in advance..
(3,065 Views)
Take a look at this code.  It should be able to be ported to the FPGA.  If it needs to range only positive, replace the negative peak value with zero.
Randall Pursley
(2,839 Views)
