SbRIO-9641 random indexing
Hello everyone. Sorry for my question if it's too easy... I'm programming on sbRIO-9641, LV2012 RT+FPGA module + NI_RIO 12.0 and try build programm for memory. Compilation this programm (pict) gives me random result, and if i set up loop timer it's shows me random result too in limits [0,160]. what is wrong?
thank you for your help!
Message 1 of 12
(5,648 Views)
I'm not sure what you mean by "Random result"  but you can definately save a shift register and an increment primitive by wiring the loop i terminal to the equals and waveform chart and wind up with equivallent code.
Message 2 of 12
(5,641 Views)
Message 3 of 12
(5,629 Views)
That can't be!  Attach the code generating that display and we'll see if it can be duplicated
Message 4 of 12
(5,621 Views)
"Attach the code generating that display"
can you explain in detail where to find this code? thank you
PS. If i debug with option "Dev Computer" the results are normal.
Message 5 of 12
(5,610 Views)
Message 6 of 12
(5,597 Views)
May be this is help (log file)
Message 7 of 12
(5,591 Views)
Hi togoto, is it possible for you to share the FPGA VI that reproduce the problem?
Alejandro C. | National Instruments
Message 8 of 12
(5,548 Views)
I add VI file
It begun then i have updated LabView 8.6 to 12 all modules and device drivers too (NI-RIO 12). On 8.6 it's worked
Message 9 of 12
(5,533 Views)
There is something wrong with that VI. It seems to me that is corrupted. Simply copy/paste the code to a new VI and save, everything will go back to normal. Smiley Wink
Message 10 of 12
(5,520 Views)
