Scale/Bin a 2-D Array
Has anyone scaled or binned a 2-D array before?  If so, could you give some information on your method?
Example of problem:
                                    initial array                 scaled array (skipped every other)
scale array by 50%:    1   1   2   2                   1   2
                                    1   1   2   2                   3   4
                                    3   3   4   4
                                    3   3   4   4
                                    initial array                 binned array (averaged in quads)
bin by 2 array:             1   2   2   3                   2.5   3.5
                                    3   4   4   5                   4.5   5.5
                                    3   4   4   5
                                    5   6   6   7
Thanks!
Message 1 of 10
(7,671 Views)
You could probably use the image resizing VI found here for the scaling (note that it gets slow for large arrays).
For the averaging, you can probably do something similar to what I demonstrated in the "Test.vi" in the attachment here.
___________________
Try to take over the world!
Message 2 of 10
(7,661 Views)
"Decimate (single shot).vi" will give you a binning in one dimension if you set the "averaging" to TRUE. So you can run this on all of the rows, then on the resultant columns.
Message 3 of 10
(6,644 Views)
(Wow, this was an very old thread (>>10 years!)  you revived here! :D)
Here's what I would probably do (but probably more scalable so a reduction factor is an input and sanity checks are performed if the input sizes are not correctly divisible).
Message 4 of 10
(6,630 Views)
I like your solution.  Should be faster.
Message 5 of 10
(6,592 Views)
For the "Input bin" and averaging=false you will get the same result, as for averaging=true.
But, for the "Input averaging" and averaging=false you will get different results.
Message 6 of 10
(6,580 Views)
Message 7 of 10
(6,580 Views)
Hey. In case anyone else encounters the need to bin 2d arrays, i made this VI :
You can also bin separately along X and Y axis. In case the bin value does not exactly divide array size, it acts as if zeros were added.
Message 8 of 10
(5,531 Views)
Hey. For the binning case on 2d arrays, i started from the answer below and extended the case to independant X-Y binning, and binning values different than 2. In case anyone else encounters the need to bin 2d arrays, feel free to use this VI :
Message 9 of 10
(5,532 Views)
Hi Adrien,
Even as you posted the very same message twice in different threads you failed to provide that VI with both messages!
All we got from you are two images, but no VI. Not even a snippet…
(Please clean up the VI before attaching the real code.)
Message 10 of 10
(5,519 Views)
