Scale Vision Image Display object on front panel
Hello all,
Currently I work on LabVIEW 2015 (64bit) with the Vision package.
I try to add an "Image Display" Control to my front panel. On my front panel the option "Scale all objects on front panel as the windows size" is active.
I would use this option to have a nice view for different screen resolution...
Anyway: The scaling of the "Image Display" doesn't really work. If the "Image Information" and the "ROI Tools" shown, there location would change randomly when I change the windows size.
Is it possible to exclude the "ROI Tools" and "Image Information" from the auto scaling? And it should stay on a defined position. for example on the upper, left edge of the image control.
Attached you would find two print screen with the issue.
Thnaks for your help,
Silvan
(3,941 Views)
Accepted by topic author silvan.murer
Hi Silvan,
I recommend you right click the image and check "Fit Control to Pane" (this will automatically check "Scale Object with Pane"). It appears to work much better than letting the VI scale everything for you. If you need to show other things beside the image, then use a splitter.
(3,904 Views)
Thanks for your hint!
(3,885 Views)
