Scale Word to print to custome size
I am making a application that will open a word document that is usually 8.5x11 and change the paper size to 12.80 x 10.24 print it to a jpeg so that is 1280 x1024 using active x controls. The problem is in that the printer is not scalling the document. How would I be able to tell word to scale to fit the page size of 12.80 x 10.24?
I have also added a custom paper size for the printer driver under the name Paperless. How would I be able to select that as a page size instead of custom page size?
(2,719 Views)
I believe you would have to play with the "PrintZoomPaperWidth" and "PrintZoomPaperHeight" options in your Document invoke node. This Microsoft page seems to confirm that:
http://msdn.microsoft.com/en-us/library/microsoft.office.tools.word.document.printout.aspx
Hope this helps!
Rob B
FlexRIO Product Manager
(2,658 Views)
