Scale by power of two and negative numbers?
Just need a quick sanity check.............
If I run a negative and scale by a negative power of two, my results seem to be one off?
for example, -1 * 2^-5 should be less than -1, so I was expecting it to return a zero.  Instead I get -1.
When my input hits -33, I get -2, so it looks like it is off?  I was doing this with a big FXP, and wanted to divide by 32 so I thought this would be a fast way of doing it...
Thanks for any input!
Message Edited by tartan5 on 04-18-2008 12:34 PM
(3,269 Views)
whoops, forget it
edit 2 - the help file for the scale by power of two says that if x is an int data type, the result is an arithmetic shift, so you might be losing data to right or left bit shifting
Message Edited by JeffOverton on 04-18-2008 12:46 PM
(3,263 Views)
From the help for the Scale by Power of 2:
"If x is an integer, this function is the equivalent of an arithmetic shift."
If you change your datatype to DBL, you get the division you were expecting.
Lynn
(3,256 Views)
I expected this would be an arithmetic shift, I just didn't think it through in binary......
-1 = 1111 1111b (for I8)
-2 = 1111 1110
-3 = 1111 1101
So it is a shift with the sign bit carried in, which for the cases above (if, say, we shift 1 or divide by 2) equals -1, -1, -2.......
Makes sense, thanks!
(3,225 Views)
