Scale cRIO NP Shared Variable AFTER Deploying an Executable
I have a project coming up that has about 140 shared variables deployed on an RT target and sharing data at 1S/s over the network.  There is nothing else going on concerning the RT target, just dumping values.  I would like to scale these SV's in the .lvproj to avoid having to write a bunch of scaling code in software.
My only concern is what happens when I have an executable application running (without LV 2012 installed on the computer).  How would I re-scale these values without having access to the .lvproj?  Distributed System Manager doesn't provide for this.  Any help would be appreciated.  Thanks.
Nathan - Certified LabVIEW Developer
(3,994 Views)
Hi Nathan,
Are you also using the DSC module? As the ability to scale shared variables is only available with this module installed.
Regards
Arham H
(3,966 Views)
Hey Arham,
LabVIEW still allows for scaling SV's without the DSC module.  I only have the RT module installed.
(3,946 Views)
Hy Nathan,
Your Shared Variables are within a library in you LabVIEW project. In your Application Properties make sure to include that library. This is shown in Figure 9 in the below white paper.
http://www.ni.com/white-paper/9900/en/
MJ
Application Engineer
(3,922 Views)
Thanks for the link, MJ.  I'm not really sure that this article addresses my question though.  Nothing speaks of how to change a cRIO NPSV once running an executable.
(3,899 Views)
You may try with Shared Variables property nodes. I'm not sure whether this requires DSC or not.
However 140 rescalings doesn't seem a lot of work to do even on the PC side.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,894 Views)
