Scale not Updating correctly
I have a very strange problem that I am hoping is an easy fix.
I have a graph that the scales are not uniform.
If you look at the graphic the Max and the Min are set however for some reason the scale isn't correct.  For example the min is set to e-6 but 0 is not in the center of the scale.  I don't know why this would be the case.
I have attached a VI with the scale problem.
Any help would be appreciated.
Dan Shangraw, P.E.
(610 Views)
Hi Dan,
Do you want a logarithmic scale?
Raphaël.
(600 Views)
Why would zero be in the center? Did you mean to put -1e+6 as the minimum? Should the scales be uniform or non-uniform?
(575 Views)
Yes I did mean to put -1e6
Oh boy...  Mathing....
Dan Shangraw, P.E.
(558 Views)
