Scaled data output from AI Read floats to maximum after switching relay
Relay turns off motor. Sensor data read from MAX remains normal, same data read with AI READ jumps to negative value then floats to maximum value over >10 seconds. I am using LabVIEW 7.1 with an SCXI-1000. Re-running AI Config and AI Start resets the data to realistic levels (matching those read by MAX). Is there an error in using AI Read with LabVIEW 7.1?
(2,404 Views)
Sounds like your AI input is unterminated. Unconnected input will cause input reading to drift/float. Check connections, contacts, wiring, relays, etc...
- tbob
Inventor of the WORM Global
(2,404 Views)
