Scaling input signals
Hi forum,
i am wondering what is the best way to scale input signals i used the scaling.vi is there another way to do it more nice.
THanks and best
Martin
(3,394 Views)
You could set up the scaling in MAX. Then when you read the channel the data is already in engineering units.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,378 Views)
ok thats a good point so i just add a scali in the to the daq task. Is it also possible to name the input channels so i dont have to do this later?
Martin
(3,366 Views)
Yes, and once you have named the channels, you can use those names to refer to them in your LV code.
Mike...
LabVIEW Champion
(3,332 Views)
Hi Martin,
is there anything I can help you with?
I think all your questions are answered, right?
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,315 Views)
