Scaling on cRIO and C-Serie card
I'm trying to configure the scale of a measurement channel on a NI-9203 board installed on a cRIO-9056.
My input is a PT100 probe wired in 4-20 mA.
I'm configuring my board via Shared Variable Propertie, on the desired measurement channel.
And I get the following error (I admit it sounds counter-intuitive...): 
However, I put the data in the right place and in the "right way". 0.02 A is well > 0.004 A ....
I can put 20 (instead of 0.02) and 4 (instead of 0.004), but of course, the value returned by the board is in A and not in mA. So it doesn't match.
Does anyone have an idea of my error?
Thanks in advance!
Message 1 of 14
(2,322 Views)
Is there a reason you are using commas instead of periods for the scaling? That may be the issue.
-Jonathan
Message 2 of 14
(2,294 Views)
The formatting of numeric is location specific and some countries use comma as decimal delimiter. This is a cosmetic issue, not related to the problem. (these are not string controls where anything goes 😄 ).
Message 3 of 14
(2,260 Views)
Indeed, commas work perfectly!
I did try it with dots, though, and it replaced them with commas.
Do you have any idea what could be causing this error?
Message 4 of 14
(2,221 Views)
Can you add your project file? I tried the same steps and did not get an error:
Message 5 of 14
(2,180 Views)
Wild guess: Under the hood everything is of course just bits from the digitizer and at one point behind the scenes your values are mapped to a raw integer. Maybe some wrapping can happen in edge cases.
Message 6 of 14
(2,173 Views)
Hello jwright30 and altenbach,
Here is the Project attached.
Indeed, when I look at the control panel of the card I see that you always several zeros after your numbers. I don't have anything.
altenbach, to be honest I didn't quite understand your comment... ^^
Message 7 of 14
(1,932 Views)
I've created a new project with a cRIO-9056 and a 9203 board, and I'm getting the same error: I can't set the right values (0.02 and 0.004).
Message 8 of 14
(1,910 Views)
Did you figure this out? I wasn't able to open the project since I use Labview 2020 and the project is in a newer version. You'll have to save it for a later version for me to open it.
-Jonathan
Message 9 of 14
(1,870 Views)
I still haven't found the solution. I've tried scaling manually in the code (only 2 measurements to adjust, so it's fine ...). But I'm still struggling to find it, knowing that I'm starting a new project today and the error is still there ... 🙁
You'll find the project in labview 2020 attached.
Thank you very much ...
Message 10 of 14
(1,761 Views)
