06-29-2015 07:11 PM
I have a USB-6211 DAQ input module with Labview 8.6, and I would like to measure temperatures using an R-type thermocouple. Since this thermocouple's voltages are very small (about 0-20 mV), I will use an external amplifier (50x gain) to transform the signal to 0-1 V, and then read the inputs using the DAQ module.
At this point, I could divide the input signal by my gain (50x) and use the reverse polynomials for R-type thermocouples (published online: http://www.omega.com/temperature/z/pdf/z198-201.pdf) to convert the voltage into a temperature.
However, I've noticed that Labview has thermocouple modules built in. There's a task creation step, and the task gets sent to a module that allows me to specify the thermocouple type, CJC value, etc., then a sample clock, then an analog wafeform sampler (see below). I'd like to use this structure rather than coding in the polynomials. However, I can't find a way to divide my input voltage by my gain (50x) in order to give the thermocouple module reasonable voltage values.
Is there a simple way to do this, or am I better off just coding in the polynomials?
Thanks!
Solved! Go to Solution.
06-29-2015 08:23 PM
Amplify the signal, read the voltage as , then divide by 50.
No need to code polynomials. Search the palettes for the subVI Convert Thermocouple Reading.VI
07-01-2015 10:29 AM - edited 07-01-2015 10:30 AM
Looks like this will work. thanks!
