Scan CSV with SI formated numbers
I have a lot of trace data in CSV format where the frequency is formated as a SI number. I am trying to read that data back in but am having trouble with the formating strings. Please see the attached example.
(3,972 Views)
Hi Viper,
there's a workaround...
(3,967 Views)
There does appear to be a problem.  Fortunately, there is a relatively simple workaround that scales a bit better than your original, but will use a bit more memory.
I have filed CAR 309897 on the issue so R&D can fix it.
(3,964 Views)
Thanks to all. My final solution with credit to contributors. I have left default data at the input to display a trace at the end. Remove data to save with a smaller footprint.
(3,941 Views)
I know this is an old post - but had a play today and noticed this: 😀
(1,207 Views)
Nice catch! You do get an error each time that you have to clear/ignore, but knowing that it's a great workaround!
Qestit Systems
Certified-LabVIEW-Developer
(1,159 Views)
