Scan From String matches all adjacent white space characters when a scan sequence to match an exact string ends with a space
I have recently written some code to parse a string using the Scan from String function.  The string contains some descriptive text as well as some parameters that I want to retrieve from the string.  My approach was use a format string that would match an exact string (the descriptive text), which removes or skips over the exact string and then match a parameter in the input string.  The remaining string contains more data that gets parsed later on.
The problem that I have encountered is that matching an exact string does not seem to work as I would expect if the exact string ends with a space.  In this case, the exact string is matched, plus any other white space characters that immediately follow the exact string.  Let me illustrate by some examples (\ codes are shown).
Case 1:  input string = "Line\s1\s\s\nLine\s2"
             format string = "Line\s%d"
             remaining string = "\s\s\nLine\s2"
             Note that the spaces and line feed after "1" are passed to the remaining string in this case.
Case 2:  input string = "Line\s1\s\s\nLine\s2"
             format string = "Line\s%d\s"
             remaining string = "Line\s2"
             Note that all the spaces and line feed immediately after "1" are removed and are NOT passed to the remaining string in this case.
The behaviour in case 2 is not what I would have expected.  Can anyone comment on this?  I can probably work around this, but would like to understand how the Scan From String function is supposed to work.  Is this a bug?
(3,060 Views)
Accepted by topic author cbfsystems
Quoting from the detailed Help:
A space in format string matches any amount of white space, such as spaces, tabs, linefeeds, and form feeds.
(3,056 Views)
Very good.  I guess the answer was just about staring me in the face.  Thanks for the help.
(3,049 Views)
