Scan Interface
Is it possible to configure cRIO 9102 Chassis under Scan Interface Mode? I am planning to use to 9012 Controller.
(3,878 Views)
Hi Cooldude,
Thanks for your post and I hope your well today.
The requirements for Scan Engine for cRIO is,
Software:
Real-Time Module 8.6+
NI-RIO 3.0+ with Scan Mode Support installed on cRIO
Hardware:
The majority of cRIO hardware does support Scan mode; however, the following do not:
Controllers: NI 9002, and NI 9004
Backplanes: NI 9101, NI 9102, and NI 9072
THEREFORE
You cant.
BUT
To use the 9102 you can do the following trick,
Using CompactRIO Scan Mode with Unsupported Backplanes
http://digital.ni.com/public.nsf/allkb/122E971F52FD081A86257500007A046C?OpenDocument
hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,861 Views)
