Scan String Token Problem with leading Tokens
Hi, I'm using the scan string for token to read in a string of tokens that contain a leading "*" char in front of each string and terminates when the token index = -2. This works great if I have say *12345*1234 and so forth, but if there is bad data, say 1234 without the leading "*" in front, the token index return value is still -1 and it returns data which I read in thinking it found the "*". Maybe I shouldn't use the string for token function since it's probably just designed for ending tokens and not data with leading tokens. Is there a way to make this work properly or should I use another method to search for leading tokens in a string?
Thanks.
Message 1 of 14
(6,838 Views)
Here is the example that describes the problem above with leading tokens 😃
Message 2 of 14
(6,833 Views)
You should consider using the Spreadsheet String to Array.  Just use * as the delimiter.  You will have to remove the first element, but I think it will get you to where you want it.
Message 3 of 14
(6,818 Views)
This vi should do what you want and will not error with or without a Leading token.  The "\*" looks for a litteral "*" rather than a repeat of "\" (That would be "\\*") Smiley Wink
Message 4 of 14
(6,816 Views)
(Don't you need to escape that *) Smiley Wink
Message 5 of 14
(6,813 Views)
Jeff, I really like your approach, but every time I run the example it returns the data starting in array offset 1 and not 0, why would that be?
Message 6 of 14
(6,810 Views)
Accepted by topic author QRP
Here.  Try this one.  It does the same thing and uses exposed functions.
The string functions look for something to mark the end of a string.  All languages that I know of do this.  So, like I said, remove the first element.  I recommend the Subarray function with the index set to 1 and length unwired.
Message 7 of 14
(6,801 Views)
I think for some reason all of this stuff is setup for ending delimitors even the spread sheet to string function. There has to be a way for Labview to be able to handle in coming serial traffic with leading tokens. I sure miss my C programming language, it's so simple that way 😃
Message 8 of 14
(6,799 Views)
That's probably how ForImStuck got into his predicament. Smiley LOL
But, no.  The spreadsheet string to array doesn't use that capability.  Probably because that is only used with file functions.
Message 9 of 14
(6,791 Views)
Jeff you are the master my friend. Your last example worked wonderful. Thank you so much!
Message 10 of 14
(6,789 Views)
