Hi Bram,
It sounds like you really understand the addressing for the AMUX64. You mentioned all the accepted ways of addressing the AMUX64/DAQ combination.
Here are some links that address this very question, though the solution uses the methods you already know:
Reading Multiple Channels with the AMUX64For the reasons that Craig Graham suggested in the other response (low-level efficiency when using the built in multi-channel methods) I suggest you get 4 channels at a time as you mentioned in the second paragraph of your post, and then extract the pertinent data from each group.
Here is one more link that deals with or
links to several topics for AMUX64 addressing:
AMUX64 Channel AddressingPlease reply if you are looking for something different than I provided.
The other reply to this question is great and really appreciated. Thanks Craig. It so happens that the AMUX64 can't handle channel strings like AM1!0:3 or AM1!0,2,5.
John Nieri
