Schedule Table LIN
I am a Newbie here. I have a USB-8476 which I am using as a master to communicate with a LIN Slave. I am able to send single frame and receive replies.
I am trying to find out an efficient way to run Schedule Table and collect data. Any examples ?
(3,843 Views)
Hi MoJ,
Have you checked the example finder that is built into LabVIEW?  You can find the examples by going to Help>>Find Examples in LabVIEW.  Once the Example Finder launches you can click Hardware Input and Output>>LIN, to see all the examples related to LIN.  Also, for the future, you may want to post questions related to LIN on the Automotoive and Embedded Networks Forum, so that you will be able to get assisctance from people knowledgeable with the hardware you are using.
Hassan Atassi
Director, ni.com
(3,809 Views)
