Scilab gateway : LabVIEW not detected
Hello everyone,
I have a problem with the Scilab Gateway. I am installing an executable made on one computer with developmental version of LabVIEW on another freshly bought computer. This executable contains a Scilab script node in it and I am wondering if the target computer (new one) needs only the LabVIEW Run-Time Engine or the whole developmental version to run the executable ?
I already installed LabVIEW Run-Time Engine 6.1 and Scilab 5.4.1 versions but when I tried to set up the gateway, I encounter this error message : LabVIEW not detected. Installation aborted.
I looked around in the forum but I couldn't find any answers precise enough to fix this issue.
Thank you in advance for your answers,
Mathieu Delavignette
(3,743 Views)
Are you really using LabVIEW 6.1? That's ancient!
(Here it says LabVIEW 8 or later)
(3,716 Views)
Well, so am I.  But, just a smidge more than 6.i
Perhaps, less ancient than a trilobyte 😗
I do try...
That silicon labs utility needs upgrade,. Unless you are targeting a pre- NT OS.  At witch point I have to ask.... What is the target OS?  Can you buy one machine that runs it without grand eBay skills?
(3,707 Views)
The target OS is windows 7
Thank you
(3,701 Views)
That will not work with that silabs sdk
(3,694 Views)
How can I solve the problem then ?
(3,641 Views)
