Scope 5160 Measurement
Dear All,
I have a requirement using NI scope pxi 5160 for measuring  capacitor charging time .
I want to measure the capacitor charging  time between 5v to 7v . Which is the trigger type to be configured and which is the scalar/array measurement function for same.
Note : pxi 5160 is not supporting window trigger
can anyone suggest me a method using scope trigger and measurement function
(2,718 Views)
Accepted by topic author VipinrajKK
I would start with a simple rising edge trigger set to 5V.
Save the scope sweep X/Y data in a 2D array.
Use array functions to find where the trace (Y data) reaches 7 volts
Calculate the period by using the sample rate your scope is set to and the counting number of samples (X data) from 5V (sample 0) to 7V
=== Engineer Ambiguously ===
(2,694 Views)
