Screen Capture
I am interesting in taking a snapshot of my front panel and saving it as
some kind of image file that i can print out on a computer that doesn't have
labview. Is there any easy way to do this? I'm not sure if Labview
supports this but perhaps a window based utility that can handle it?
Caleb
(3,796 Views)
Platform = windows?
Activate window, Then use Alt-printscreen, Open (for example) Word, and use
Ctrl-V.
Can't be easier I think...
Hope this helps
Ronald
Caleb Tennis schreef in berichtnieuws
3a39140a@newsgroups.ni.com...
have
> Thanks,
> Caleb
(3,796 Views)
Hi Caleb,
you can use WinGraber.
I send it to you directly.
Mike
> Thanks,
> Caleb
(3,796 Views)
Try Paint Shop Pro. www.jasc.com It has window capture utility that is very
easy to setup. You can also save the images as JPG instead of BMP. This
would reduce your Word file size significantly.
Jeff
"Caleb Tennis" wrote in message
news:3a39140a@newsgroups.ni.com...
have
> Thanks,
> Caleb
(3,796 Views)
Jeff
have
> Thanks,
> Caleb
(3,796 Views)
