Screwy graph scale behavior
Does anyone know why this would happen?  See picture.  Sometimes it looks as shown, sometimes the scales don't over lap each other but are spaced either behind the black graph background, or off the screen.  I can reset the scale layout and it all returns to normal, but as soon as I run it, it screws up again.  It does this when I turn the graph scales off, then back on again.
(3,199 Views)
Can you attach the actual vi? What lv version is this?
(3,195 Views)
Oh yeah, it's LV2010.  The actual VI is quite large.  I just wondered if this was common and if there is a known reason for it.
(3,193 Views)
I've had trouble with this since LV7.0.  This has gotta be a bug and I can't believe that NI doesn't know about it.  Why haven't they fixed it?
(3,181 Views)
