Script-Example POST
I would like to rewrite or start this Skipt via LV.
But I've no idea how to realize it.
Can somebody give me a hint?
$empfang = "12345;23456;777777;88888888;999999";
$request = "";
$param["id"] = "XXXXX";
$param["pw"] = "XXXX";
$param["type"] = "2";
$param["empfaenger"] = $empfang;
$param["absender"] = "testapp";
$param["befehl"] = "Temp +10";
$param["reply"] = "1";
$param["reply_email"] = "E-Mailadresse";
$param["termin"] = "TT.MM.JJJJ-SS:MM";
$param["id_status"] = "1";
$param["massen"] = "1";
foreach($param as $key=>$val){
$request.= $key."=".urlencode($val);
$request.= "&";
$url = "http://www.meineseite.de/app/test.php";
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $request);
$response = curl_exec($ch);
curl_close($ch);
echo $response;
(4,875 Views)
Hi Wulfi,
can you explain a bit more? Where do you have problems? Which part do you want to rewrite, where do the new data come from?
Mike
(4,871 Views)
I want to give some values to a php site and then i get a value back..
I want to send and receive this data without the Internet exploerer becuase otherwise the logindata is displayed.
(4,858 Views)
Hi Wulfi,
you can use HTTP to send your parameters to your php page. See this link for an example
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=324049#M324049
Another possibility is to use the IExplorer ActiveX Control.
Mike
(4,849 Views)
You may want to look at this post on the LAVA forums that dicusses using curl with LabVIEW.
(4,848 Views)
Thanks.
Now I found a variant to control the IE via ActiveX and make it invisable. So it works.
(4,838 Views)
