Script VI Properties Separate Compile Code option
The VI Properties General category has the boolean option "Separate compiled code from source file".  I would like to be able to set this through a script.  Is that option included in the scripting nodes somewhere?
We have many projects in SVN, none of their VIs have this property set so every time a minor change is made the result is a long list of VIs being added to the change list for commit.
Message 1 of 8
(2,614 Views)
Accepted by topic author randoghsp
Not sure about scripting, but if you open your project, there is a project option to mark all items, it will be applied the next time they are saved. Maybe that's all you need.
Message 2 of 8
(2,608 Views)
Here is a simple VI that I put together (save in LV16)
Santhosh
Soliton Technologies
Message 3 of 8
(2,596 Views)
Both options are perfect.  Thanks 🙂
Message 4 of 8
(2,589 Views)
I am curious if there is a reason why there are two loops instead of one?
Message 5 of 8
(2,575 Views)
Yes, I am ensuring all the files are loaded into memory before changing the property, thereby every VI need not spend time loading the same dependencies over and over again.
Santhosh
Message 6 of 8
(2,556 Views)
This setting is also available for control properties.  Should it also be set there or is that just a noop.
Message 7 of 8
(2,530 Views)
Not obvious. You could try both and compare the size of the *.ctl file. 😄
Message 8 of 8
(2,510 Views)
