Script Wiring to Sequence Frame
I want to use scripting to create a wire to a Flat Sequence Structure.
How do I do that?
Message 1 of 8
(3,472 Views)
Accepted by topic author paul_cardinale
I think you would first start with creating a tunnel on the Sequence Structure and then wire the numeric control to that tunnel.
This is how it is implemented if you are creating FSS from scratch.
https://github.com/DBTaylor/lv-scripting
You can try some of the LV Scripting toolkits available on VIPM - could avoid reinventing the wheel.
Santhosh
Soliton Technologies
Message 2 of 8
(3,467 Views)
Apparently that only works with a Stacked Sequence, not a Flat one.
Message 3 of 8
(3,458 Views)
Here's how I would do it, create a dummy object inside the Flat Sequence, wire to that, then delete the dummy object.
Message 4 of 8
(3,453 Views)
Oh Yeah, the snippet I shared was for Stacked Sequence Structure but I assumed that it will be similar for Flat Sequence Structure too.
Santhosh
Message 5 of 8
(3,452 Views)
Are you sure it's wired correctly?  😄  You know I had to say it.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(3,443 Views)
😄 "Wire correctly"?  It wasn't wired at all.  That was my problem.
Message 7 of 8
(3,410 Views)
Since I only needed one frame, I just used the Stacked Sequence.
Message 8 of 8
(3,405 Views)
