Scripting Express VIs
With scripting, is there any way yo determine whether a SubVI is an Express VI?
Is there any way to script the conversion of an Express VI to a standard SubVI?
Message 1 of 9
(3,494 Views)
Accepted by topic author paul_cardinale
You can read the Is Instance property of the VI to see if it is an Express VI:
As for programmatically converting to a subVI, there is a private method for that. I've attached a password-protected VI (saved in LabVIEW 2014) that wraps the private method. Note that use of this method is not officially supported by NI.
Message 2 of 9
(3,458 Views)
Thank you.
But I hate your icon.  Try this: ic.png.
Also, shouldn't you have closed the VI reference?
Message 3 of 9
(3,446 Views)
Eh, my text-based icon is more readable. 😉
Also, what are you doing looking at that diagram?
Also, I wasn't sure if that private method would invalidate or otherwise mess with the VI reference, so I didn't close it. I don't think it matters much either way.
Message 4 of 9
(3,437 Views)
I hate looking at a block diagram that's got a bunch of white icons with little black squiggles in them.  At a glance, they're harder to differentiate.
I usually look at block diagrams (even when I'm not supposed to).
Also, I was under the impression that any non-GObject reference coming out of a property node should be explicitly closed.
Message 5 of 9
(3,432 Views)
Yes, that's usually true. In this case, we're replacing an instance VI with another VI, and I figured there was a good chance that the original instance VI reference would no longer be valid. It wouldn't hurt to close the VI reference, but I'd probably ignore its error output.
Message 6 of 9
(3,426 Views)
Is that also true for application references?  When I get an app ref from a property, should I explicitly close it?
Message 7 of 9
(3,367 Views)
I discuss the topic of "which references to close" in my Brainless LabVIEW presentation. Here are the relevant slides:
Message 8 of 9
(3,363 Views)
Unfortunately that also yields true for a malleable VI.
But this works:
Message 9 of 9
(3,286 Views)
