Scripting - Find path of missing VI on block diagram bug?
I have a block diagram with missing VIs that I would like to find the missing path of. The propery "MissingPath" works for standard sub VIs and static dispatch VIs but fails on dynamic dispatch VIs even though the path is shown in the Context Help when I hover over it. Instead it returns Error 42 - Generic error.
Is this a bug?
Test VITest VI
ResultsResults
Example project attached. Missing VIs are intentional - just click ignore all and run Missing path test.
(2,895 Views)
I'd say it's a bug. Haven't found a proper workaround either...
BTW. (might save someone a few clicks) those properties don't exist jet in at least 2013. So opening the VI in 2011, 2012 or 2013 is pointless.
(2,841 Views)
Thanks.
Didn't think to check that the property existed in older versions - good catch!
(2,838 Views)
The (brown, private) VI Linker Errors returns the VI name, but not the class name. So does the (brown, private) Get Missing Dependencies Information.
Label.Text on the SubVI also gives the VI name but not the class...
(2,834 Views)
Useful to know. I also tried them with the missing VIs in a diagram disable structure and it didn't report anything in the Linker errors or missing dependencies (I guess that would be expected as the VIs are not required to execute). I had a situtaion like this the other day which created conflicts, but couldn't find them. The VI still ran without problems.
(2,826 Views)
