Scripting get index for a case
i need the index of a case, so i can add some code. But i get Error 1305, if try to get the index from case name.
Can some one tell me what is wrong with my approach?
(3,317 Views)
Accepted by topic author wladimiripg
If you read the FrameNames property after writing it, you'll get the following:
So in order to use the GetFrameIndex method, you'll have to specfy a frame name of ' "Test4" ' (including a space before and after the quotes).
(3,290 Views)
(3,269 Views)
