Scripting "Retain All Errors"
Is there a way to script this?
(1,840 Views)
I also couldn't find a equivalent option through scripting, let's see if someone else can find the right node.
Santhosh
Soliton Technologies
(1,826 Views)
When there's no official scripting property/method, I always try playing with the BasicObjectFlags:
(1,773 Views)
I had already discovered that bit 17 of the BOF corresponds to “retain all errors”, but BOFs scare me.
(1,746 Views)
If ever NI developers choose to change the bit field mapping across versions, it may result in Chaos, but this does looks promising when validated for each version.
Santhosh
(1,728 Views)
Another option, which is probably safer, is to manually create and save a VI with an object which has the relevant properties, and then copy the object from that VI programmatically.
___________________
Try to take over the world!
(1,715 Views)
Though a workaround with additional steps in the scripting, this sounds more robust.
Santhosh
(1,659 Views)
