Scrollbar does not get active
I am using XY graph to display temperature Vs. Timestamp. I need to use scroll bar for my graph. I have enabled scroll bar for X-axis but it doesnt seem to work. It is always disabled and grey. I need data points on my plot to be spaced out so that I can analyse and see the data in a better way. Also LV reads the whole data log file at once. I need to delay it for each data point and display it on graph. Can anybody help me out with this problems.
Thanks in advance,
Ratnesh
(2,837 Views)
The reason your scroll bar is disabled is because you are displaying the entire data set. If you were to enter a different start or stop time, the scroll bar would be displayed. To enter a different start or stop time time, just highlight which one you want to change and type in a new value. If you want to do it programatically, turn off autoscale of the X axis and then you can use a property node to set x min and x max. If you want to display data point by point like a chart does, what I would recomend is that you read in the entire data set like you're doing but instead of wiring it directly to the XY Graph, wire it to a for loop with a wait statement inside. There is a shipping example called XY Chart that you should look at. It uses a subVI called XY Chart Buffer that manages the data. If you put the subVI and the graph inside the for loop, you should get what you want.
(2,828 Views)
