Scrolling position in SubPanel
I have inserted a picture as a device context in a subpanel so that I can build à fast rollingGraph and easily navigate in the picture.
The problem is that I cant find information about srcolling position in the subpanel and this information can be very important if I want to draw scale by the picture.
Does anyone have a solution?
Pierre Delvart
(3,545 Views)
Hi Pierre,
What do you mean by scrolling  position ?
Which type of information do you want to get ?
thanks in advance for your reply.
Best regards
Alexandre D
NIF
(3,523 Views)
with the properties of the subpanel you can show vertical and horizontal scollbars.
Want I want to get is the current position of the scolling in the panel. so that I will be able to determine the origine of the visible part of my subVI and then act on its changes.
thanx very much for your interest.
Pierre
(3,513 Views)
