Search 1D Array not accepting string array (LV2020)
As the title says the Malleable VI Search 1D Array (unsorted) in Lv2020 (v20.0.1f1) will not accept a string array. I can't find "old" non-malleable version in the toolbar but copied it from the Malleable "Seach Unsorted 1D Array.vim" file. Is this a bug?
(2,554 Views)
Accepted by topic author cbudtz
Once you connect the "element" input to a string source, the array input will no longer be broken.
(2,522 Views)
Almost every one of us has been there and realized after some time that you need to wire the element input for it to work.
Santhosh
Soliton Technologies
(2,506 Views)
Thanks guys. Just me being impatient I guess!
(2,490 Views)
You might want to give the following thread a good skim.  There are a few posts in there about restoring the Search 1D Array primitive to the palettes and you can use that instead of the new malleable VI version.
Search 1D Array ... Changed in 2020 SP1
(2,450 Views)
