Search 1D array-searching numbers in a range-
I want to search in a 1D array, a range of numbers, for example numbers between 10,005 and 11,005... The only thing here is I cauldnot find a way to search numbers in a range instead of a specific number. Anyone that has an idea about this situation please help me...
(3,982 Views)
The simples solution when you only have 1 area of interrest is using the "In Range?" vi.
If you have more area's you can use following method:
Use the Threshold 1D array vi.
Build a range array with 0, 9.005, 10.005, 11.005, 100.
Now wire your array via a loop to the "threshold y" (enable indexing).
Wire the range array to the "array of number of points" input (disable indexing).
The output-array is the index of what area each value is in.
(3,981 Views)
