Search 2D Array
Since you're looking for an array (row) in a 2D array the basic Search in 1D array wont really cut it. However, LV is clever enough to compare array with a normal = command. So by looping through the 2D array you can compare the row with the 1D ones following the same logic (-1 for not found, stop search on found) with the following:
22721i488A420D67F9CA38
or like this (at 2nd thought i like this better)
22723iD0717D5624051DEC
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 15
(1,813 Views)
We're almost there.
For's solution can get rid of one boolean operation if the comparison is set to compare aggregates. Also the "select" needs to be done only once, and not with every iteration of the loop. (not sure if the compiler can recognize it as loop invariant code...probably not).
Yamaeda's solution above needs a FOR loop instead of a while loop, eliminating evaluation of the extra termination condition.
Here's what I would do:
Message 12 of 15
(1,802 Views)
To be fair, Yamaeda is using LV8.2.  But, for those of us "living in the now", the For loop is the way to roll.
Message 13 of 15
(1,796 Views)
Ah, OK. I did not read the signature... 😉
Message 14 of 15
(1,793 Views)
Well I'm running 2010 at home for a while longer, didn't think about the aborting For.
/Y
Qestit Systems
Message 15 of 15
(1,747 Views)
