Search Ordered Table VI
Dear All,
I am using the tool  '' Search Ordered Table VI '' which is shown in the attached picture.
please please I need someone to help to understand the exact principle of this tool, as I use it and I need to explain how this function work. I have checked the manual and it seems not enough information about it.
I wish if someone could help with this.
Thank you in advance for your attention
best regards
Thoalfukar
(3,383 Views)
Open up the VI and look at its block diagram.    It has some comments to tell you what it's doing.
(3,359 Views)
There are very few and I couldn't understand the code from that comments
(3,318 Views)
Hi Thoal
The help for this functions explains it very well:
  • Works on the assumption that ordered x array is in monotonically increasing or decreasing order and can therefore efficiently search for the relative index of the location of x value within the x array.
  • The VI starts the search at the starting index and begins by using a fast hunting phase to roughly bracket the location and then narrows to the final bracket using a bisection search.
  • The VI computes the fractional index location by using linear interpolation.
So what are you missing from this explanation?
(3,312 Views)
Ok... I wish if you can a little bit patient with me.
now if I want  to explain this tool in my own words, just to write about it in my paper.
would the following be convenient:
The principle of its work:
First: define whether the values of the powers within the LUT are ascending or descending.
second: defining where is roughly the location of the of the power within the LUT in order to narrows  or partitioning the search area. After that the search will be within a small brackets, and if the exact value is not within that packet, the nearest index within that packet will be picked up.
best regards
(3,304 Views)
Yes.
(3,301 Views)
Suppose I said "I'm thinking of a number from 1 to 1000.  You can "guess" 10 numbers, and I'll tell you if it is my number, or if it is too high or too low".  I'll also say that the right algorithm will always converge to my chosen number.  How would you do that?
The algorithm is called "Binary Search", and I'll leave it to you to either figure it out (hint -- Binary Search) or look it up.
Bob Schor
(3,286 Views)
