Search Path Field Height
We have a large LV developer user base and our users are getting confused by the limitations on the search path fields. The lowercase q really looks like a q (see below), any ideas on how to change this to make it more clear?
Thanks!
Using LabVIEW2012 32bit
(3,262 Views)
Ironically, in your message both characters "lowercase g and looks like a q" they both look the same. I understand, looking at the image that you are saying lowercase G and lowercase Q look the same, apparently because the field height clips the image?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,259 Views)
I'd be suspicious of something with the windows fonts settings.  All of the characters look slightly different, almost coarser, than I would expect.  It seems like a bad font scaling where things are being scaled slightly larger or smaller.
(3,241 Views)
Hmm I see the same behavior on my Windows 7 machine and a Mac OS X 10.8 machine as well. Changing system fonts didn't seem to make a difference for me. I'm going to ask around here to see if anyone else has a workaround, and file a Corrective Action Request if necessary.
(3,233 Views)
