Search VI for Representation Type (DBL, SGL, etc.)
Is there any easy method of loading a VI and search through all the types to determine what the Representation type is?  I need to convert a ton of VIs from DBL to SGL and would like to be able to know if I've converted them all.  Any ideas?
Derek
(3,488 Views)
Depends on what you mean by "easy". Smiley Wink
You would need to use VI Server functions to open a reference to the VI and get the pane's controls, and then for each control you can get the value as a variant and then use the "Get Type of Variant" VI that resides in the vi.lib\Utility\GetType.llb library. For example:
(3,469 Views)
There is a second way, as well, but it requires the use of a private property. Private properties are not normally visible, but can be turned on using the added keys that are mentioned in the scripting forum over at the LAVA web site. The private property "Bit Accurate Data Size" will tell you whether it's a DBL or SGL.
(3,466 Views)
Accepted by topic author Derek Price
Thanks - I'll try this!
Derek
(3,436 Views)
