Search for a the same string in a .txt file horizontally
I am struggling with searching for a string horizontally. I am able to get the first value but i want to obtain the next value with the same name down the txt file?
thanks
(928 Views)
Accepted by topic author KJ26
Hi KJ,
So you want to search "horizontally", whatever that means...
The SearchString function has an input to indicate the search position. Maybe you should use this "continue" your search after the first found item? (Seems the answer should be to RTFM 🙂 )
(921 Views)
