Search in a array for a negative number and replace with a zero
I want to search in a array  (double 64-bit)  for a negative number/s and replace it with a zero.
Br
Message 1 of 8
(7,168 Views)
I would use In Range and Coerce and coerce the array to between 0 and +Inf.
Message 2 of 8
(7,166 Views)
If you don't like that suggestion (I personally do), you can always use the same brute force method used in every other programming language.
Message 3 of 8
(7,112 Views)
Accepted by LVdummies
Probably the quickest option in this case 😉
CLA
Message 4 of 8
(7,082 Views)
That's clever!
I ran a benchmark on that vs the coerce method and MaxMin is about 13x faster. Kudos!
Cheers
Message 5 of 8
(7,065 Views)
I was curious about the time too and found it was about 20x faster using the max min. I also found that the brute force method was about 6x faster than in range and coerce.
Message 6 of 8
(7,058 Views)
What the heck, I always assumed that VI must be faster than brute... Maybe it's best with some datatypes? Weird.
Cheers
Message 7 of 8
(7,048 Views)
Sorry, I meant that the brute force is about 2x faster than in range and coerce. And the advantage does appear to go away when using I32 datatype.
Message 8 of 8
(7,040 Views)
