Search string and return data
Hi, I'm new to labview. I have a string (Data1: A, Data2: B, Data3:C.......), I need to go through this string to fetch the data, regardless of the order. Example: look up Data2 and return only B. But I need to do this for a set of Data1 or Data2 and etc, my string will contain a lot of data.
Message 1 of 17
(5,232 Views)
Hi Rafael,
what have you tried and where are you stuck?
What about SearchString function? What about a loop to repeat the search?
Message 2 of 17
(5,227 Views)
Actually I tried several options that I found in the forum but none served me, my idea was this a search and a loop and with that go through the string and fetch the data that I need.
Message 3 of 17
(5,220 Views)
Hi Rafael,
Then you should create a VI following that idea of yours.
Come back when you have specific questions!
(Like that "what is your problem and where are you stuck?")
Message 4 of 17
(5,212 Views)
If all your data is in one line (no new-line constant), you can transform string into array.
Then you can search throw 1st column and take correct element from 2nd one.
Message 5 of 17
(5,210 Views)
It did not work here. Labview 2012.
Message 6 of 17
(5,197 Views)
Of Course you can't place strings into "double" numbers
Message 7 of 17
(5,189 Views)
Perfect, now it worked. Now I need to scan this array and fetch only the data I need. Example: fetch the data B from the variable Data2.
Message 8 of 17
(5,179 Views)
Yes, you should scan array for "name" and select correct element from second col
Message 9 of 17
(5,176 Views)
Could you give me an idea how I can get the row and column and just show the data I need? Example: Show B of Dados2 (row1, column0) in a variable of type string.
Message 10 of 17
(5,155 Views)
