Search string in Array
I have one 1D array in that array the elements are started like 04_02_26LS1004(format is yy_mm_ddserialnumber).I Dont know the array size. It may go more than 60000. I want to search the elements which are all matching for the first 8 characters(yy_mm_dd).I don't need to compare one element by one element using for loop.Please Suggest.
with regards
R.sathiyanarayanan
(3,681 Views)
i can't think of any other way than using a for loop and compare each element with the match pattern function. Since you are only comparing for a a part of a string the search array function won't work.
Chris
(3,681 Views)
You could sort the array, and then do a binary search for 04_02_26AA0000 (lowest possible according to ASCII table) and 04_02_26zz9999 (highest possible according to ASCII table) which should represent the lower and upper regions of the array sub-set containing these numbers.
You may need to do a bit of fiddling to test either side of the returned index values to make sure you have the correct index but this should work I reckon.
Regards
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,681 Views)
Dear Shane,
Thanks for your valuable solutions.the solution given by you is working fine for me. Once again thanks
with regards
R.Sathiyanarayanan
(3,681 Views)
