Searching for Staic VI References
I recently found out about a neat way to open vi references in labview by using the static vi reference.  Today I tried to open an app in 8.5 and couldn't because of a whole bunch of bugs and problems with labview 8.5.  Then when I looked at the 8.5 known issues page I saw:
4CKERKC3 Building an application that contains a VI that has a static VI reference to itself throws Error 7
Building an application that contains a VI that has a static VI reference to itself fails throwing the following errors: "LabVIEW cannot find a file that is a dependency of a Startup, Exported, or Always Included VI. File Not Found: The missing file might be referenced by one of the libraries included in the build or by the file - test.vi." or "Error 7 LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer."
Workaround—Don't use static VI referece, instead use the Open VI ref prim, passing it the the Current VI path constant.
Date Added—09/27/2007
Return to top
Now I am very worried.  If this didn't work right in labview 8.5, does it work right in labview 8.2?  Is there a way to search for static references in a project?  I realize now that it is a new feature and I should have never used it.  But now I can't rememeber all teh places I used it.  Any suggestions?
-Devin
I got 99 problems but 8.6 ain't one.
(3,159 Views)
That sounds like one of my bugs and I probably found it in LV 8.2.
If you open all of the top level VI's, then serach all of the VI's in memory, it should show up.
Ben
Message Edited by Ben on 10-18-2007 12:00 PM
(3,152 Views)
Perfect!  I didn't even realize you could do that. Thanks.
-Devin
(3,138 Views)
