Searching for a string using "Match Pattern" or "Match Regular Expression"
   I would like to use the "Match Pattern" or the "Match Regular Expression" vi simply because of the outputs that these vi's provide. The output I am interested in is the "after substring". I want to be able to specify a "substring" and get whatever is after the substring from the input string. However I am getting all confused and/or hosed up when it comes to "regular expressions". Is there a way to create a "regular expression" that will act as is it is a "substring" to find within the input string?
   The substring is a partial dir path that contains colons, backslashes, etc that are part of a directory path.  So some how the "regular expression" input has to ingnore all of the special characters and simply figure out where the substring is within the input string and give me "all of the stuff" after the substring in the "after string" output.
Kaspar
(6,638 Views)
The back slash (\) used in a file path is also a special character in regular expression so you must precede any back slash that you wish to find with a back slash. Like “C:MyDir\\MyFile”
Colons are ok.
Post an example of what it is you are looking for and I will create a regular expression for you.
Omar
Omar
(6,631 Views)
   Here is a example of a of the string value that I want to send to the input string
        \\crnas03\home\my documents\test_folder\dir1\dir2\dir3\dir4\file.txt
Here is the input string that needs to be tweaked to turn into a "regular expression"
I am aware that I will have to uses the "seach and replace" vi to modify it. I would like to get the following output
 \dir3\dir4\file.txt
Kaspar
(6,608 Views)
Accepted by topic author Kaspar
Use Match Regular Expression instead of Match Pattern; it's better.
Jim
(6,598 Views)
  It works! Thank you!
Kaspar
(6,587 Views)
Hi there, thank you for your answer. I completely forgot about escape characters in strings! Anyway, this works for me using both Match Regular Expression as well as Match Pattern. You said to use the former, as "it's better." Could you elaborate on why you say that Match Regular Expression is better?
Thank you
(4,215 Views)
From the context help, Match Pattern "gives you fewer options for matching strings".  That's all.
Jim
(4,202 Views)
