Searching ^ symbol using regular expression
I have a text file as an input string containing 2 columns of date and equation separated by a tab.
Now I want to read that file and search for a specific equation like x^10+5 and replace it with something, so my search string looks like this:
19-07-2021\t3x^10+5\n
this works fine if I search it without using regular expressions but this will only work for a specific date and I want to make it any general date, so I tried:
[0-9]+-[0-9]+[0-9]+\t3x^10+5\n
but this is not giving the result(in fact it is not giving me any result) that I want because of the "^" symbol.
So please help me in searching 3x^10+5 using regular expression.
I hope that I was able to explain my problem properly. Please let me know if something is still not clear.
Thanks in advance
Best regards
Ankit Yadav
Message 1 of 8
(3,578 Views)
Escape it with a \.
Special characters (., [, (, *, +, $, ^, ], ), \, {, }, |, perhaps others) (often) needs escaping.
Message 2 of 8
(3,564 Views)
According to manuals found in the internet I'd try
\xhh
where hh is replaced by the hexcode for the circumflex sign.
Regards, Jens
Kudos are welcome...
Message 3 of 8
(3,558 Views)
Note that the help mentions that LabVIEW uses the PCRE library.
So, most online information on that library can be used for LabVIEW regular expressions
But some dialects aside, googling "regular expression ...", for example "regular expression capturing groups", will very often give usable results.
Message 4 of 8
(3,553 Views)
\xhh
Regards, Jens
Simply \^ should work.
Message 5 of 8
(3,551 Views)
Accepted by topic author yadavankit9999
You need to use '\' before any special characters.  So you need to add it before the '^' and the '+'.
Message 6 of 8
(3,542 Views)
Thanks, everyone for your quick responses.
I tried this:
and as you can see, \^ didn't work without using \+ as crossrulz mentioned. Thanks for it crossrulz.
Thanks, Jens for letting me know something like \x5E, it worked(somewhat) and replaced the ^ symbol only. Like:
as you can see it didn't work if I search for \x5E+5( I don't know what I should input in the search string to replace the whole equation😞).
Ankit Yadav
Message 7 of 8
(3,535 Views)
I tried this:
Ankit Yadav
You need to escape all special characters (as mentioned in the 1st reply).
So you also need to escape the +. "E+" matches one or more "E". "E\+" matches "E+".
To add to the mix, you can also use \136, where 136 is the octal value for ^.
Your expression "\x5E5+5" matches "^55", "^555", and so on.
Use "\x5E5\+5"
Message 8 of 8
(3,521 Views)
