Second Monitor Problem in LabVIEW 2012
I am using LabVIEW 2012 for a client.  Whenever I right click on the control panel the toolbox appears in the wrong place.
It appears lower and about 40% of the screen width to the right.
Why is this happening, (doesn't happen on other applications)?
Message 1 of 8
(5,906 Views)
What does the question have to do with a second monitor?  Does it only occur on the second monitor?  Please be more specific.  I don't know what would cause this so these are just guesses (in no particular order):
  • The block diagram is extremely large.  This is probably not likely based on your attached screenshot that has no front panel objects and the VI has not been saved with a meaningful name (Untitled 2).
  • Some random mouse setting that was turned on by accident.  (i.e. Click Lock)
  • An accessibility or Ease of Use setting.
  • Faulty mouse driver.  Reinstall drivers.
  • Faulty mouse.  Try a different one.
  • Faulty Windows session.  Restart computer.
aputman
Message 2 of 8
(5,843 Views)
Thanks and apologies for not explicitly restating that the issue only happens on the second monitor.
It only happens with LabVIEW front panel.  I can actually dial into a remote PC on the second monitor and it works fine...  puzzling!
Message 3 of 8
(5,815 Views)
You might try changing the resolution of the second monitor and see if it still happens.  Other than that, I do not know.  It sounds to me like some sort of anomaly with your computer or your installation of Labview.
aputman
Message 4 of 8
(5,804 Views)
Thanks, have tried all the usual, maybe I need to reinstall LabVIEW as you suggested.
Message 5 of 8
(5,796 Views)
It's likely because your monitors have different DPI scaling.
This post might be interesting, but I don't know it will necessarily help.
You can make it work by disabling DPI scaling in the LabVIEW exe, but then you have no scaling (duh!) which will likely make it much harder to use your main monitor.
My workaround is to just not use my second monitor for LabVIEW. I keep a browser with forum/guide/hardware manual etc or git bash and so on there instead.
Brief edit: Although the above describes my experience in LabVIEW 2015, it seems to be working (without disabling scaling) in 2016. Weird (and fantastic).
Message 6 of 8
(5,783 Views)
Close LabVIEW. Delete LabVIEW.ini open LabVIEW. Fixed📣
Why?  The floating panels location is saved in the ini without proper checking of window bounds.  It has been fixed
For those more adventurous. You may try editing the fplocations key by hand but, resetting the ini to default is much safer.
Message 7 of 8
(5,778 Views)
Thanks Jeff,
Where do I find labview.ini.  It doesn't seem to be in program files : D:\Program Files\National Instruments\LabVIEW 2012
Message 8 of 8
(5,545 Views)
