Second Z axes on 3d CWGrapf
Hello!
Simple question: Is possible to add second z-axes (with different range) on CWGraph?
If yeas send me a procedure please!
Hot regards!
(2,509 Views)
Accepted by topic author Toni2
Hi Toni2,
I have been playing around with this and I do not believe it is possible to add a second z-axis with a different range to the CWgraph3D ActiveX control.  It seems that you are limited to multiple plots referenced against the same z-axis.  You can always just scale the data for the 2nd plot before sending it to the graph, then explain your scaling elsewhere.  I know it's not exactly what you are looking for, but it could pass for a solution!
Brian A.
(2,485 Views)
