Second part of Flat sequence not getting executed while given inside a for loop
Hi all,
I am using LabVIEW to control an XY stage with benchtop stepper motor controller, in a sequential pattern.
The movement of Y axis for 10 mm should be followed by movement of X axis for 10 mm, and this has to execute for 3 times. I have used a flat sequence and a for loop for this operation.
However, the first frame of flat sequence is getting executed three times as given in a for loop and the VI gets stopped before executing the second frame of flat sequence.
Required pattern: (Move Y axis for 10 mm, move X axis for 10 mm)x3
VI returns: (Move Y axis for 10 mm)x3
No error window is appearing when the VI is being executed.
The VI is attached here (RelativeMotion.vi). Anyone who understands the error in the VI, kindly respond.
(1,116 Views)
Hi Varsha,
This is impossible due to THINK DATAFLOW!
The 2nd frame will be executed before the loop can start the next iteration!
A statemachine would be a better approach…
Did you disable automatic error dialogs?
Why is there no error handling at most of those "MG17" property nodes?
Why are there no error indicators to show (possible) errors when executing your VI?
Did you debug your VI? What did you determine while doing so?
(1,110 Views)
